1 - 20 of 21 Posts
Hi everybody I am try to fix a problem for a friend. THEENGINE IS a BRIGGSANDSTRATON 16 V TWINN VANGAURD MODEL#303707, iM NOT GETTING POWER TO THE SOLENOID if i turn the key it wont start unless i unplug the soleonid wire and put power to the end of it with a jump box.then it starts right up. replaced the igmition swith still no good no power .WHEREdoes the soleoind draw its power from ??? Any Ideas would be greatful..
Thanks bucko64
Pyro Ill check for grounding on it if i run 12 volts to it it starts and runs fine just cant get it through ignition it dont make sense to me?? I tested through the wire of the plug wire is good ??? :freak:
Thanks bucko64
goto the ignition switch, but leave it plugged it, take a test light and goto each plug and turn the switch on and off, the there should be 1 that lights up on you, that will be for the fuel solenoid. Usually the wire runs right down the side of the tractor, goes into a plug, than the wires go behind the starter, underneath the head, and then to the carb
also, while typing this I just thought of something, I once ran into the same problem you are having, the wires that ran behind the starter, got pinched, I loosened up the starter, moved the wires, and that fixed my problem
Discussion Starter · #8 ·
Thanks for the help guys. I ran 12 volts down to the solronid from the pin on the back of the ignition plug wire is good just cant get it through useing the ignition swith . I will double check my saftey swithes. Ill get back to you guys. It dont make sence to me .....bout ready to hang this one up..:confused:
Bucko64
there are several switchs you can get that may look the same but aren't. make certain your new one is exactly the same as old one. start there. then match up the wire goin to the solenoid and take your meter and see if your getting DC voltage through switch. might be a brand new switch but have had them be bad from factory. just my .02 cents.
The best way to resolve your issue is to start at the solenoid and work your way back through the electrical system. Locate the wire in question at the wiring harness plug and test for power there at both sides. If no power there, then trace the wire back to the switch and test again, follow the path of power all the way back to the battery until you locate the issue and then you can repair it.
Discussion Starter · #16 ·
Hey guys the orignial ign. swith was 5 prong black plastic new one is 6 prong meatel i gave the guy the part # he picked it up for me. But in the package directions said ok for black 5 prong just dont use the 6th prong what do u guys think about that..
bucko64
It's possible.
What is the model number of your tractor?
What is the part number of the switch you installed?
It may or may not make any difference, if the switch is not the problem!
Discussion Starter · #20 ·
Good News Guys. Lessens learned never work behind somebody elses work and take for granite the job was done right.Buddy put the soleind for the ignition on before i got the mower to my place he had the wireing all messed up. I looked up the wireing diagram this mornig soon as I seen it I said OOO Sheet..Its working fine now
Thanks to u guys I didnt give up.:)
Bucko64:wave:
1 - 20 of 21 Posts
