Howdy all! Well I've been plugging away at my track.
Its taken a little longer than I had hoped. Back in the early summer, the 1:1 race season kicked on and the little cars went on the back burner for a while. Then in July, chest pains sent me to the hospital, where I was awarded a quad bypass operation
that has pretty much kept me on ice since then.
The good news is, its given me time all the time in the world to work on my table. Thankfully the table itself had already been built so not much heavy lifting. Been going over my track pieces, checking connectivity, joints etc. (sometimes the Tomy track can be a bit rough in that regard...particularly the original non-Racemasters version of the 18 inch curve - yikes :freak:.)
Anyway, I've run into something I don't quite understand, and I'm wondering if the more electronically proficient members of the Hobbytalk faithful can give me some insight.
I've always understood that as far as power taps, the conventional wisdom seems to be one tap per 12-15 joints. However, I laid out my track (photo below) and it all seems to be working quite well. I hemmed and hawed and thought maybe I could get away with 2 power taps. There's 40 joints on the track, and if I put one on the main straight and another at the halfway point, then I should be ok. (we're box-stockers anyway)
For reference, If I do that, then the taps would be effectively on either side of the yellow car in the photo.
Just because I was curious, I pulled out a multimeter, hooked the power up, and put an elastic around the controller in the wide open position. I got a reading of 20.5 volts right at the power source. I went around the track, and even at the furthest point from the power track, I was still reading 20.5.
Is this a fluke, or am I reading the wrong thing? I would have thought that the further I got from the power, that the reading would go down.
By my estimation, I'm thinking that I'm not losing power anywhere...and that maybe an additional tap is not even necessary?? I'm still gonna put the second one in...already made the power tap track, but just wondering what's going on.
Also....second question, is there any wisdom about where exactly power taps should and should not be placed? I have a race buddy who swears up and down you can't put a tap too close before a curve or the cars will go flying. That just doesn't make sense to me...its not like the cars get a surge of power when they hit a power tap...or do they?
Anyway, below is a photo of the yet to be named "Circuit de Shadow" I'm quite happy with the layout and the way it runs. I wanted it fairly simple, devoid of spaghetti esses, and with lots of room for grass, pits, billboards etc. The motif will be sort of a cross - a saturday night short track, road course style.
Thanks for watching!
