erock1331 said:
I think learning all the "small tricks" would be key - figuring out the timing, getting all the upgrades like the bearing and sintered rotor and installing it right. Not ever running BL that is what would concern me.
Truthfully I don't think there are to many "small tricks" other than getting your chassis to work. Figuring out the timing is probably easier than with the brushed motor...leave it where the factory sets it. From what we have found it really does not do much to adjust the timing.(at least with the Novak system) I'm not saying it doesn't do anything, just not enough to really make a difference. Being able to adjust the timing at the ESC like you can with Tekins is a different story.
The upgrades with the sintered rotor and bigger bearing are nice, but it is not necesary to do. If you have the correct Rollout for each (sintered / standard rotor), you will be equally fast with either one.
I think there are many more "small tricks" to figure out with a brushed motor than there are with a brushless to be concerned about.
Having run brushed motors since '82 to about 1 1/2 yrs ago, I am not basing my opinion or comments on just running a brushless motor.
RC
