Anyone seen this new NOVAK GTX esc in action? Any comments will be appreciated. Thanx :thumbsup:
Novak's Smallest & Most Powerful Racing ESC Ever!
Think small. Really small. Now think powerful. High-tech. Rugged. Durable. Orange. These are all accurate ways to describe Novak’s newest, smallest, and lightest speed control ever: the GTX, the new benchmark for programmable racing ESCs. Go ahead, measure it and compare it to other ESCs, Novak or not, and you’ll learn that the GTX is one of the smallest, lightest, and most powerful competition ESCs currently available.
While new to the public, the GTX has already claimed several race titles (including current IFMAR 4WD World Champion!) thanks to world-class drivers having used it in events across the U.S. with victorious results. Among its wins are World and National titles, as well as champion of prestigious annual races. An impressive debut, indeed. Here are just a few of the racers and their titles who were GTX-powered:
Ryan Cavalieri 2003 IFMAR 4WD World Champion
2004 Reedy Race Champion (Open Modified)
Mike Blackstock 2004 ROAR Carpet National Champion (1/12 Modified)
2003 Cleveland U.S. Indoor Champion (Modified Touring Car)
Jukka Steenari 2004 ROAR 4WD Modified National Champion
2004 Losi 4WD Off-Road Champ
Brian Kinwald 2004 Cactus Classic Champion (Modified Truck)
2004 Speed World Cup
Ralph Burch 2004 Snowbird National Champion (Touring Car)
Greg Hodapp 2004 KO Grand Prix Champion (Modified Touring Car)
Thanks to sophisticated new MOSFET technology, Novak was able to design a significantly smaller, lighter, and more powerful ESC than ever before (1.11” x 0.86” x 0.60”; 0.64 oz). The best part is that the small size was achieved without sacrificing any of Novak’s signature features such as One-Touch Set-Up, Polar Drive Circuitry, and Radio Priority Circuitry. It also has Digital Anti-Glitch Circuitry, and is the only programmable racing ESC with built-in Thermal Overload Protection and a 36 Amp Schottky Diode. So not only is the GTX extra small (it’s even smaller than Novak’s XXL receiver), it’s packed full of features, power, and built to withstand the rigors of competitive R/C racing.
Equipped with Novak’s Variable Throttle Step Technology, which delivers 1300 discrete steps for both drive and braking, the GTX delivers incredibly smooth performance. The 100% digital, microprocessor-based ESC has ultra-smooth throttle response at all frequencies (up to 11 kHz), as well as the quickest response to change in transmitter signal (<60µS); all this from the smallest size and lightest weight competition ESC in any class!
Part of the GTX’s unique makeup is that it is built with six layers of gold-plated powerboards, which help increase its power-handling capabilities. Externally, the GTX also features low-resistance gold-plated PCB Direct Solder Wire Tabs. When used with the included Novak Super-Flex silicone wire, users are assured of the lowest possible voltage drop, as well as easy and convenient power wire and power capacitor replacement. The GTX uses the strongest BEC (6 volt/3 amp) available, which allows faster servo response and better torque-holding capability. For a perfect fit in any vehicle, a user-replaceable combination input harness/power switch that comes with both a long and short length input harness is included so you can get a custom looking install without having to figure out what to do with the extra wire.
It’s hard to believe, but within the tiny GTX case resides 7 throttle programs that are pre-programmed for nearly every driver, application, and track condition. For advanced users, or people who like to tune everything, Novak has incorporated a 7th program that can be customized by using the One-Touch Set-Up button (no external programming device required). Four different color LEDs help make programming even easier by providing prompts. The 7th program offers similar settings to the other six programs, but allows you to adjust Drive Frequency, Minimum Drive, Brake Frequency, Minimum Brake, Dead Band, and two different types of braking: standard Constant Force Braking or Drag Brakes.
The GTX was designed with the competitive R/C driver in mind who demands not only a small, lightweight ESC, but one that can deliver superb performance. The GTX delivers all of the above and more.
GTX PROGRAMMABLE RACING ESC SPECIFICATIONS
Input Voltage: 4-7 cells
Case Size: 1.11” x 0.86” x 0.60” (28.2 x 21.8 x 15.2 mm)
Weight: 0.64 oz. (18.1g) [with heatsink, without wires]
Motor Limit: None (Any brush-type R/C Motor)
On-Resistance:0.00034 ohms
Rated Current: 150 Amps @ 25°C MOSFET Temp.
Braking Current: 60 Amps @ 25°C MOSFET Temp.
B.E.C.: 6 Volts/ 3 Amps
Schottky Diode: 36 Amp Built-In
Maximum Discrete Steps: 2600 (1300/Forward, 1300/Reverse)
Battery/Motor Wire: 10”/14G (12AWG can also be used)
GTX PROGRAMMABLE RACING ESC FEATURES
Microprocessor-controlled
7 Throttle Programs
On-Board Programming w/4 Color Status LEDs
Gold-Plated PCB Direct-Solder Wire Tabs
User-replaceable combination Input Harness/Power Switch
One-Touch Set-Up
Radio-Priority Circuitry
Polar-Drive Circuitry
GTX PROGRAMMABLE ITEMS
Throttle Programs: 7 (6 fixed, 1 customizable)
Drive Frequencies: 1 of 7 (1-11 kHz)
Minimum Drive: 1 of 5 (2-12%)
Brake Frequency: 1 of 5 (1-6 kHz) Standard or Drag
Minimum Brake (all programs): 1 of 7 (0-50%)
Dead Band: 1 of 5 (2-6%)
Drag Brake: 1 of 7 (0-50%)
$ 174.00 Tower Hobbies
:roll:
7 Throttle Programs
One-Touch Set-Up
:roll:
