Hi all.....Just wanted to say hello. My name is Matt and I've recently been given a 1970 JD 726 snowblower. As you can imagine, it is in pretty rough shape thus the term given. Anyway..... Tecumseh H70 with your typical carb issues from sitting outside for so long. But the biggest issue is no spark, which is why I have joined this great forum after lurking as a guest for about an hour or two. I have already found some great advise from many members with similar problems and will attempt them today....hopefully (temp is 22) brr. Just a quick recap if some of you were wondering....new carb kit installed after a very good cleaning.....new points and condensor but still no spark. Will check all connections and do a good sanding of all contacts to make sure I have a good ground. I hope this solves the issue, if not then a new coil will be next. Thanks again for a great forum.
:thumbsup: Matt
:thumbsup: Matt
