1 - 15 of 15 Posts
Hi folks :)
Can anyone here possibly help me by converting PDF's into Coral Draw files?
Any help would be greatly appreciated :)
Tony,
Corel is my middle name! Sure it makes for a funny monogram, but hey.
You should be able to just open pdfs like other files. go to file> open then click on the pdf. if there are more than one page, select which page. This works quite often, but you might have an issue if the pdf was secured.
let me know if this doesn't work
Lou
Thanks a million Lou. I'll relay that info and see if that works. If not, I'll let ya know :)
Raist...I will tell you that as far as I know, there is no way to convert a PDF into another file format.
However, you can open the PDF in the selected software and generally drag the image into a new file in the software. If it a drawn image or something like that then it will not be editable, but you could probably trace the image if you wanted to change it.
Discussion Starter · #5 ·
Thanks Martin, how about converting a JPEG into a corel draw file?
Tony,
you can bring a jpg into corel and then save it as a .cdr, no problem.
now the jpg will still be a bitmap, so if you are looking to turn it into a vector image, you'll need to trace it once you have it in corel.
Discussion Starter · #7 ·
Thanks Lou, that's what I would need then. Someone who can take a few JPEGS and save them as CDR for me.
Raist you figure it out? If not you can give me the Jpegs and I can see what I can do. :) (i'll PM you).
update:
Tony I never got the PM cause my inbox was full, I deleted some messages now though.
Discussion Starter · #10 ·
A huge thank you to both Lou and Fiercegaming. Thanks for coming thru for me guys :)
If you open a PDF in Adobe Acrobat, you can save it as JPEG, TIFF, EPS, PNG and a few other formats. You need the complete Acrobat application, not just Acrobat Reader.
Yeah that would work too I would think. All you need is an EPS and that can be brought into corel draw and saved as a .cdr. Or if you already have the jpegs and you have photoshop you can open them there and save them as an eps's (you will need the eps plugin though). Then you can bring those eps's into corel draw and save them as .cdr's. Well atleast thats what I ended up doing for Tony. Both ways should work.
Discussion Starter · #14 ·
D'OH!! I have paint shop Pro X and I can save the PDF's as an EPS file!!
Don't know enough to have known.
Thanks again guys :)
Yeah you can just use .eps in correl, works fine. I probably could have told you that but I didn't know ethier until I downloaded the program and saw it could take .eps. I knew it couldn't take .jpegs and thats about it. So just had to convert. Well now you know :). Again anytime Tony.
1 - 15 of 15 Posts
