need help!!!!!!!!!
838 Views 4 Replies 4 Participants Last post by  Rentahusband
hello, i have a toro model 26622, serial num 00180001 and it has to warm up on choke for a minute and after that it surges. any help would be appreciated! thx
It's getting to much air or not enough fuel.
If there is a fuel filter (not familar with this model), clean it.
Leave the gas cap off and try it.
Spray some Carb cleaner/starting fluid around the intake flange while it's running and see if that changes the behavior.
Good luck.
I don't think you need to make any governor adjustments, the carb is dirty, remove the carb and give it a good cleaning and you will solve your problem, just be careful because parts may not be available for that engine. Have a good one. Geo
thankyou both i will try and let you know the outcome thx!
I just cleaned that same carb on a Toro mower that was a freebee. Mine ran fine at full throttle, but surged when idleing. Disassembled the carb, cleaned it. Now it purrs like a kitten. If you do the same, it should solve the problem.
