Hello: New to the site. Found this site while looking procedure on how to put the clutch spring back. I just replace the deck and while pulling the engine off the older deck I remove the clutch cable from the engine side where it is attached to Arm Brake. Now the spring does not want to go back and requires a lot of pressure which I cannot exert.
Question for you guys is: Is there a special way to put that spring back? I do not have shop manual and didn't observe how it was attached prior to pulling it off.
Thanks
msk
Thanks
msk
