21 - 28 of 28 Posts
They are much easier to install. The top spring is the proper orientation. The ends rest against the bulkhead and the opposite end sits across the pickup shoe.
When you are putting the chassis together load the traction magnets and then push a spare rear tire doughnut between the traction magnets. Helps keep them in place when you are putting the motor & bulkheads into the chassis.
If your car has the black pan style chassis it might break if you try to insert the traction magnets after everything else has been assembled.
21 - 28 of 28 Posts
