This just in for my personal car!
Hi, Rob -
A little information on the car, tech and maintenance: Lotus 38, #82 (1965 Jim Clark Indy winner)
Features:
1. Steel rod frame with bonded, lightened G3 motor box
2. Fabricated styrene front bulkhead, body/shoe-plate mount, with G3 guide pin
3. Floating polystyrene, rubber tube and polycarbonite shoe plate, with G-Jet pick-up shoes and PlanetEngineers 26 gauge ultra-flex, multi-strand silicone wire
4. Mabuchi M30 motor with .062 armature expansion plug
5. BSRT Nylatron gearset: 7-tooth Pinion, drilled to .062 with shortened boss; 20-tooth Crown, lightened with beveled gear and boss edges
6. BSRT Titanium, splined rear axle spaced with .005 stainless steel spacer
7. BSRT Marcos rear wheels with White dual compound silicone tires dyed Black
8. XXXXXXX
9. Detailed MagnaTraction O-ring plastic front wheels, acrylic sealed
10. Polycarbonite body, with replaceable styrene suspension rods in rubber tube mountings, reinforced with ripstop nylon tape.
11. Detailed Lotus historic livery with polystyrene driver: sealed with three coats of Acrylic wax.
All paints are Parma FastKolor and Pactra RC Acrylic.
Specifications and Requirements:
1. Mabuchi M30 motor with 1.5-2.0 volt minimum requirement, 7.5 volt MAXIMUM rating.
2. Controller settings should be set as you would run with your G-Jet cars.
Maintenance:
1. To remove the car body, remove the rear axle assembly. Spread the front nose of the body, and slide-out the mounting rod from the heat-shrink tubing. Slide the body forward from the motor box mounting tubes. Reverse process to mount body.
2. Oil the motor bushing every one-half hour of running with one drop of high-grade synthetic motor oil. I have used a 50/50 mix of Prolong (or Z-Max) and Automatic Transmission Fluid on the motor and axle, with great results (also works great for the T-Jet).
3. To clean the rear motor bushing, remove the body and axle assembly, and use a quick burst of high-grade motor cleaner, such as Trinity Motor Spray. It will not harm the motor-box.
4. Clean the tires as you would any dual-compound; tape or a mixture of water and a drop of Dawn detergent will work well.
Should you have need of repair, just ship it back to me: I will repair for cost of parts and postage.
I think that is about it!
Rob, thanks so much for your interest in these cars!
I hope you enjoy them as much as we do!
Later...
GK
