What all did you have to do in your restoration?
Great paint job!
HAL9001-
It's a very long story that I documented on another board.
The short version goes like this:
I bought this kit at the begining of the year because the price was pretty low - but it required a lot of work.
You won't be able to see all that was required, but in a nutshell the make-up kit - one of the central pieces of the model - was a shambles. The two fold-out trays were broken apart and the pieces that held them together, that made them sit inside the main case, were gone.
Those "connectors" had to be resculpted which was done using Aves.
The main case also had three sections broken off and those sections had to be resculpted.
The packing crate was misaligned (not square) and gaps were filled with glue.
The stool was missing one of the horizontal spacers.
The base and columns were lost under thick black paint and black was the primary color of choice on the busts making them featureless.
Everything had to be broken down and stripped.
Once the paint was off the pinholes that were never filled became visible.
A good part of Chaney's hair was sanded smooth and had to be rescribed.
The Chaney figure had to be disassembled to get rid of the thick paint and give me access to the full figure for a complete overhaul.
I airbrushed much of the kit although all the facial features on the four faces were enhanced using pastels - a technique I'd never tried before.
I'd also never tried doing a faux marble effect but I wanted that look for the busts' pillars. The technique turned out to be really easy.
But the most time consuming feature was the pinstripes on Chaney pants.
I spent at least 12 hours (which translates into days) masking the stripes.
And believe it or not the above is the
short version of what I did on the kit!
Thanks for your interest.
Derek
