I picked this up about two or two & a half weeks ago to do as a side project while I'm waiting to get my Stealth back on the road. It has certainly needed its fair share of work, but I'm within a day of finally being able to take it for its maiden run around the house.:cool: The only things I haven't been able to locate so far for it is a replacement, era-correct front tire set and a thrust bearing set.
These are photos of how it looked when I first got it...I'll update this thread with what I've done so far once I get a chance to resize them to forum-specific sizes.:thumbsup:
Discussion Starter · #2 ·
More Photos
Here's how it looked after stripping it down some:
Enough solder to probably do all of the connections on the entire electrical system!!!:freak: I'm also quite positive that this wasn't the correct solder, too.:rolleyes:
The Novak 610-HRV that came with it...Notice how it was ran without the smallest heat sink & the consequent melting along the edges.
After doing some cleaning on the motor's terminal posts:
All cleaned:
More Photos
The ESC before repairs:
And after:
And finally one with mostly everything reinstalled on the chassis:
Enjoy!!:cool:
Update: The rest of the necessary parts should be in later today, so I can finally test out the electronics!!
Chassis Complete (minus the mangled front tire)
Here's how it is as of today. I got everything mostly figured out on it, except I cannot get the ESC to recognize reverse. Some more messing around should do it, but if not at least it still has forward & I'm a decent driver.:p
Pics:
Chassis:
Chassis with the body installed (I still need to restore the body, so please excuse the old damages):
I forgot to mention that I did manage to find a new pair of front rims that I'll be sticking on as soon as I can get some era-correct front foam tires for it.
