1 - 1 of 1 Posts
New MUGEN SEIKI original parts has back on shelf. See below for the product information and choose the best parts for your machine.
Where to buy:
http://www.rcmart.com/catalog/mugen-seiki-mugen-mrx4-c-595_741_615.html
C0723
MUGEN SEIKI (#C0723) Engine Mount Flat Screw for Evo D0240
MUGEN SEIKI (#D0240) Center & Rear Belt D0508
MUGEN SEIKI (#D0508) Diaphragm D0509
MUGEN SEIKI (#D0509) O-Ring Set For MSX/MTX3/MBX/MRX/MST/MTX4 (Discontinued) H0136-B
MUGEN SEIKI (#H0136-B) Rear Upper Arm for MRX-4X H0137
MUGEN SEIKI (#H0137) Front Lower Arm for MRX-4 H0141
MUGEN SEIKI (#H0141) Front Anti-Roil Bar Holder For MRX-4 H0142
MUGEN SEIKI (#H0142) Radio Plate Mount for MRX-4 H0148-B
MUGEN SEIKI (#H0148-B) Front Bulkhead for MRX-4X H0163
MUGEN SEIKI (#H0163) Rear Anti-Roll Bar for MRX-4 H0185
MUGEN SEIKI (#H0185) Rear Adjustable Anti-Roll Bar Set for MRX-3 H0222
MUGEN SEIKI (#H0222) Rear Axle Shaft for MRX H0240
MUGEN SEIKI (#H0240) Rear Belt S (8mm) H0245
MUGEN SEIKI (#H0245) Front Belt S (6mm) for MRX-4 H0246
MUGEN SEIKI (#H0246) Rear Belt S (9mm) For MRX-4 H0247
MUGEN SEIKI (#H0247) Side Belt L (6mm) for MRX-4 H0252
MUGEN SEIKI (#H0252) Front One Way Drive Axle for MRX H0257
MUGEN SEIKI (#H0257) 2 Speed Adapter H0268
MUGEN SEIKI (#H0268) Axle Washer H0269
MUGEN SEIKI (#H0269) Middle Shaft for MRX H0271
MUGEN SEIKI (#H0271) Front Axle Shaft for Universal H0273
MUGEN SEIKI (#H0273) Joint Shaft for Universal H0282
MUGEN SEIKI (#H0282) 1st Gear (49T) For MRX-4 H0285
MUGEN SEIKI (#H0285) 2nd Gear (46T) For MRX-4 H0286
MUGEN SEIKI (#H0286) 2nd Gear (47T) For MRX-4 H0287
MUGEN SEIKI (#H0287) Shoe For 2 Speed Gear Box for MRX-4 H0288
MUGEN SEIKI (#H0288) 1st Gear Housing for MRX-4 H0290
MUGEN SEIKI (#H0290) Rear Solid Axle for MRX-4 H0291
MUGEN SEIKI (#H0291) Rear Drive Shaft for MRX-4 H0295
MUGEN SEIKI (#H0295) Spring For 2 Speed Gear Box for MRX-4 H0296
MUGEN SEIKI (#H0296) Rear Universal Joint Set H0369
MUGEN SEIKI (#H0369) Ventilated Brake Disk H0468
MUGEN SEIKI (#H0468) Rear body Mount Centering Shaft For MRX-4 H0469
MUGEN SEIKI (#H0469) Rear body Mount Arm Shaft For MRX-4 H0470
MUGEN SEIKI (#H0470) Rear body Mount Arm Stopper For MRX-4 H0471
MUGEN SEIKI (#H0471) Rear body Mount Arm Pin For MRX-4 H0473
MUGEN SEIKI (#H0473) Front body Mount Plate Cfrp For MRX-4 H0475
MUGEN SEIKI (#H0475) Chassis For MRX-4X H0516
MUGEN SEIKI (#H0516) Front Spring (BU) For MRX / MTX / MSX H0531-PK
MUGEN SEIKI (#H0531) rear spring 2.0 (Pink) (Discontinued) H0532
MUGEN SEIKI (#H0532) Rear Spring (RD) For MRX / MTX / MSX H0558
MUGEN SEIKI (#H0558) Damper Piston 1.2mm (BK) H0560
MUGEN SEIKI (#H0560) Front Damper Stay For MRX-4 H0561
MUGEN SEIKI (#H0561) Rear Damper Stay For MRX-4 H0566
MUGEN SEIKI (#H0566) Front Damper Stay (NEW) For MRX-4 H0570
MUGEN SEIKI (#H0570) Damper Set H0571
MUGEN SEIKI (#H0571) Damper Parts For MRX-4X H0707
MUGEN SEIKI (#H0707) 1:8 Clutch Shoe H0751
MUGEN SEIKI (#H0751) Flywheel for MRX-4 H0755
MUGEN SEIKI (#H0755) Spring Adjust Nut H0760
MUGEN SEIKI (#H0760) 2nd gear 19T MRX H0761
MUGEN SEIKI (#H0761) 2nd gear 20T MRX H0771
MUGEN SEIKI (#H0771) Clutch Set for MRX-4 H0772
MUGEN SEIKI (#H0772) One-Piece Engine Mount for MRX-4 H0775
MUGEN SEIKI (#H0775) Centrifugal Shoe for MRX-4X H0780
MUGEN SEIKI (#H0780) Clutch Set for MRX-4X H0801A
MUGEN SEIKI (#H0801A) Steering Rod for MRX-4 H0853
MUGEN SEIKI (#H0853) Roller Pin 3x11.6 H0854
MUGEN SEIKI (#H0854) Roller Pin Set H0862
MUGEN SEIKI (#H0862) Steering Rod H0866
MUGEN SEIKI (#H0866) Fuel Tank for MRX-4 H0901
MUGEN SEIKI (#H0901) Manifold Spring H1006
MUGEN SEIKI (#H1006) Rear Spoiler Adjust Screw H1011
MUGEN SEIKI (#H1011) Rear Spoiler J0209
MUGEN SEIKI (#J0209) Middle Shaft T0154
MUGEN SEIKI (#T0154) Eccentric Hub for MTX-4 Where to buy:
http://www.rcmart.com/catalog/mugen-seiki-m-90.html
1 - 1 of 1 Posts
