1 - 1 of 1 Posts
Tamiya RC (58414) Mercedes-Benz Unimog 406 - CR01 Series U900 has been Restock!!
*Click the image to buy
About the Model
  • The Mercedes-Benz Unimog's body is made from lightweight polycarbonate material.
  • CR-01 chassis features a heavy-duty ladder frame with strong lightweight pressed aluminum channels and cross channels.
  • 4 link coil suspension provides the flexibility needed to conquer difficult rocky terrain.
  • Center gearbox features planetary gears with a compact design enabling the battery to be mounted lower for a better center of gravity.
  • Newly designed 3-piece beadlock wheels mounted with massive 125mm diameter and 56mm wide rock crawler tires are ready for any terrain.
  • Powered by a 540 motor.
  • Can be fitted with Yellow (Front) and Red (Rear) TLU-01 LED Lights (ITEM 53909)
  • The Unimog is compatible with a wide range of Option Parts
Specs
  • Full Ball Bearings
  • Planetary gearbox comes with20T pinion gear for a 40.5:1 gear ratio
  • Requires ESC and 2ch Radio w/1 servo
  • Requires Paint and Assembly
ELECTRIC KITS REQUIRE:
(unless stated differently above)
Radio: 2-Channel with servo(s)
Battery: 6-cell flat with standard Tamiya connector
Charger: AC/DC timed or peak for 6-cell battery
Paint: PS for Polycarbonate/TS for ABS
Misc. Items: Building and track equipment
Source: Tamiya USA
Where to Buy CR01?
http://www.rcmart.com/catalog/rc-tamiya-58414-mercedesbenz-unimog-u900-p-27656.html
Where to Buy CR01 hopup & Pasts?
http://www.rcmart.com/catalog/tamiya-cr01-hopup-parts-c-595_744_1158.html
1 - 1 of 1 Posts
