I know this isn't strictly a small engine question, but I'm guessing someone here will have the answer. The blades on a Sears riding mower I recently bought are a bit bent, and I'm wondering if I can straighten them. I know hardened steel is prone to break when bent back, but I'm wondering if mower blades aren't hardened enough to be that brittle. Any advice will be appreciated.
Rick A.
Never Bend blades back, they can shatter when run at high rpms. Just buy new blades, they are only around $15 each.
Justin is right. I straightned out some blades on a John Deere and 2 cuts later one of the blades shattered and went half way through the outer housing. The damage was not limited to the housing and blade. I had to replace the shaft, balance spool and the suspension above the housing. BUY NEW BLADES.
Thank you for your advice. I had an idea you couldn't bend high carbon steel back. I'll definitely not try it!
Rick A.
