1 - 3 of 3 Posts
Now that I have my track up and running, it's time to mount and fine tune the joints. Most of my joints are good, but I do have some that aren't as smooth as I would like them. So what process do you recommend? Mount than fix, fix then mount, or fix as I mount?
I fixed before mounting. Then found I had to fix again after mounting. I'll fix as I mount next time.
Super Moderator
Been there - did that!
I use the plumbers level kit as I work my tracks now. (A pocket full of change. Today it's cheaper than buying washers or spacers!)
If you ever move your track - all that adjustment can also be lost. Even if you have a pulley lift system or a hinge mounted wall track.
1 - 3 of 3 Posts
