Anyone tried these? I don't have a pager, but the last toothbrush I bought has one! I gather the vibrating weight can be easily removed.
Some ideas:
-nacelle lighting effects, in small starship models
-turning radar masts
-spinning propellers
-small railroad signals and crossing gates
-small figure animation
What's the dimensions? I have been considering hiding motors in my model cars with flexible shafts for electric windows, wipers, turn the belts and fan, etc.
I may hvae to round up some junk pagers and check them out!
Discussion Starter · #4 ·
hotwheelsbob said:
What's the dimensions?...
Size ranges from small, to I-can't-believe-it's-a-motor. You can also buy gearboxes and gearheads made just for pager motors, since they're used in robotics.
Google "pager motors"; you'll be surprised!
The motor inside Hitech's HS-55 servo is slightly smaller in diameter than a pencil eraser. Lengthwise it's about as long as the metal ferrule that holds the eraser. It would easily fit inside a small 1/72 aircraft.
What size/type of battery do they use, where are they available, and does an electrical doofus like me need to worry about Ohms and such ?
Dabbler
4 or 5 cells, 41/2 to 6 volts for the r/c stuff. Thats the voltage needed for the receiver to function properly. I'll bet the motor alone would tick over at half a volt.
