What irishtrek said.
You can spray enamel over lacquer (after it has dried or "gassed out") but you cant spray lacquer over enamel. The hotter solvents in lacquer will soften the enamel and cause crazing, tiny cracks. You can use something like Duplicolor auto primer or any of the Tamiya flat whites. Always test though on scrap when useing two different brands of paint on a plastic kit, especialy lacquers.
Correct.
For those who don't know:
Lacquer isn't acrylic, nor is acrylic a lacquer base. Why they call it "acrylic lacquer" is a misnomer. It's actually acrylic in a high solvent base which dries similarly, but if you mix the two together you get mush!! :drunk: It cracks all over, and crazes (turns white). NEVER spray real lacquer which is made from nitrocellulose fiber - not acrylic over any other finish. It's too hot, and it will dissolve the other one below it. Only if it's hardened for more than two to three years can you spray lacquer over another finish, but I don't recommend it. M.E.K. (Mehtyl Ethyl Ketone) is the harshest of solvents, and will dissolve skin on contact if left without washing off immediately! This is what gives lacquer its kick. This isn't found in acrylic formulations.
Acrylic, and enamel can be mixed without fear of damaging one another, but that's mainly because the formulation of each is a soft resin. It's also mostly comprised of acrylic rather than enamel. This is what 90% of all paints are going to now since they've decided that heavy solvent based paints (alkyd) with oils are harmful to all life, and the air that we breathe. My local hardware store has decided to take all their alkyd products off the shelf due to a new governmental restriction. Just remember to test for compatibility on scrap. Spray your primer coat (if used) and any other subsequent coat of base colour, then let dry for a few days. Once dry, spray the clearcoat over it to see if it wrinkles. If it does, then the formulation of the clearcoat is much higher solvent based than the undercoat colour layer. This means that you need to ensure that you're using the exact same paint base formula from the base colour on out. This will keep it from mismatching in solvency. If you're unsure, ask the company for an MSDS (Material Safety Data Sheet) for the explanation of the contents, and their proposed usage. This may save you a lot of grief.
~ Chris
