1 - 20 of 29 Posts
I wanted to spread the word about Micro and Mini-Z racing Monday nights at The Hobby Shop (that's the name) in Dayton, OH.
We've moved outdoors, weather permitting, and had ***26*** Mini-Zs at the last race and will now start racing 1/18th scales as well. Even Mini-Ts if enough show. If it R**ns, then we'll run the ozite track indoors.
Power is available for charging. We start at 7:00pm, so show up no later than 6:30-6:45 to get signed up.
Standard Classes right now are:
Mini-Z "-o1" stock
Mini-Z "-02" stock
Mini-Z Modified (Hop-ups allowed, rubber tires)
Mini-Z Outlaw (Anything goes--must use Mini-Z body)
Mini-Z F1 stock and modified
Micro (MRS4, M18 etc...) Just starting--run what ya brung.
It a great, low-key time with emphasis on fun.
For directions: www.thehobbyshoponline.com
-Mike
Discussion Starter · #4 ·
Micro_Racer said:
Can we run the BRP SC-18? We whip on the MRS4 and M18 so alot of tracks won't let us run....
We'd run them with the 6-cell/big block Micros, or separately if the BRP cars get tired of getting beat. LOL
Seriously, I'm sure all will be accomodated.
Discussion Starter · #9 ·
We had 19 cars last night. Heats of 01, 02, Mod, Outlaw, and F1 Mini-Zs. Plus a heat of 5 micros.
For Micros, foam tires worked best. Orange and Magenta.
My sides actually hurt from laughter after the Micro Main.
Mike,
Just wanting to needle you a bit.
I've seen many Micros plagued by rolling in the corners. Clearly, not your car.
I know what you mean about laughing while racing. At Da Track we often find the same thing. I want to race 18th at CORCAR and I told Bud he should come down and run. It will be a while before he does. Can we talk Paul H. and Michael T. and some others into bringing and running their 18th scale?
I'd really like to see what the M18 can do in capable hands. The only one I've seen raced was on carpet and he was rolling it in the corners on a large road course.
David
Discussion Starter · #13 ·
Well, we're way off subject...but that's okay.
1. 1/18th racing has been dead since winter in Dayton, Cincy, Columbus, and WV. I was happy we got 5 on Monday. People are buying some chassis parts and hop-ups, so it looks like we'll get some more.
2. As far as CORCAR, we need 5 to make a class. It looks like a lot of guys went to the Pan Car class as their second class. I can't say I blame them, since they're the cheapest thing going. I have about 50 buck into mine.
3. The M18 has a problem with too soft a spring. Why are the springs so soft? Because if they weren't, the suspension arms would flex. I helped design the Penguin M18 performance upgrades. Those will alleviate that problem.
4. As far as MRS4 are concerned, most chassis makers try to make the rear end real flexible, like a 1/12th scale. That's why they also roll in the corners. The chassis sets that are stiffer are the way to go...Penguin's, ARM's, The Orion's.
It would be great to see some micro racing again at CORCAR. I bring the whole garage to CORCAR in case we ever have a class. Hope to see you soon. In the meantime...it's:
MONDAY! MONDAY!! MONDAY!!!
Discussion Starter · #15 ·
Great racing again last night...
Around 25 entries. Micros were the biggest class with 7 with couple more forthcoming in the next few weeks.
Most people are running the Penguin R/C P3500EL chassis with 6-cell AAA and the stock motor.
-Mike
Discussion Starter · #17 ·
WARBIRD said:
Around what time are you finishing up??
Well, the racing finishes around 9:30. Then the REAL RACING starts and finishes around 10:00 (grudge races). Of course, then you have the post-race smack-talk that finishes by 11:00.
In other words, you could leave at 9:30, by why would you want to?
-Mike
okracer said:
what is this penguin r/c p3500EL chassis ? anyone have a pic or a website
Penguin RC...
Micro chassis for Entry Level.
http://www.penguinrc.com/products/hpi/p3500el.html
Similar to the American Racing Models pan chassis except
Penguin's is a little more sophisticated and like the ARM chassis
is made from G10/fiberglass. Penguin's is 1.5mm or just under
0.060 of an inch thick (1/16th)
RAFster
David
1 - 20 of 29 Posts
