If you're running 1cell, make sure you have it in Nimh mode because the Lipo mode has a cutoff built in based on 2cell voltage. I would think if it was in the wrong mode, it would cutoff right away though......Anyone having problems with them shutting down 2 minutes into a run. Reset it , changed rollout, tried all i knew to do. Any help would be greatly appreciated..Bobby
i called and talked to Sean Cochran and he said they did not have the higher timming settings its for mod racing onlyQuestion about the new SXX. Are the timing profiles the same as the SPX or the Comp 2007?
:thumbsup:I ran one this weekend Bobby and what I did was pull the red wire out of the plug that goes to your receiver. Then you can use the switch to power on the speedo. Mine had to be put on Nimh or it would shutdown. Disadvantages to this are now you have 2 switches if your running the smc pack...Advantages are you dont have to worry about a turn marshall flipping the switch on and smoking it...lol
hush......its painted now....lol:thumbsup:
You had cool graphics on your COT too.
dk
Just curious if you ever pinpointed what fixed the problem for you?Thanks for everyones help....She works good now !:wave:
