Need a little info. I have heard about running in #6 setting. I'm running a Novak Ballistic 13.5 with the SPX. I've been using it in mode 7 with the timing on the motor set in the middle. Motor comes off the track around 128 degrees or lower. Can I bump the timing up on the motor or should I go to mode 6 and crank the timing on the motor?
Thanks.
Thanks.
