My little wonder blower has a 5hp Briggs engine.I cant get it to run,I removed spark plug put gas into cylinder fires ,runs a few seconds and that's it .Any ideas on what the problem might be...thanks
carburetor... check that? does everything flow.. and when was the last time you cleaned it? may be gummed bad... or the gas tank is rusted? and hows the pickup tube? is it FRESH gas or is it ****** color or smells funny? check diaphram too
Sprayed starting fluid into carb, while it ran for a short time I sprayed it with carb cleaner,repeated 3 times and now its running fine again..thanks for all the help
