1 - 2 of 2 Posts
I recently bought a OFNA LX-1e and have installed a Novak HV 6.5 brushless system, I need to know can I get away with running one battery instead of two. If so what size and how many volts? I am only using the car for bashing with my kid's Emaxx's, and I reallly don't care if it runs the same speed(maybe a little quicker) and aound the same runtime, 15-20 minuntes aprox.
Any help would be great
check you speedo and find out what it will hold volt wise. i would say fun a 2s 5000mah 30c 7.4 if you want more power the to got the 3s if your speedo can handle it. just remember that the volts X number of turns times X 100= rpms your running. i think is how you get your rpms.
i know the more voltage the more power. its all in what your speedo can handle. you should get about 15-20 mins on run time. we hold 15min heats at the track so and ppl here are running 5.5 -3.5 brushless
just watch you gearing so you dont over heat your motor or speedo
1 - 2 of 2 Posts
