1 - 17 of 17 Posts
Looks interesting enough. I gather you're referring to the 1:350 E-A? I see they do DS9 with the Xenoline. With this larger Enterprise, I would imagine it would work. I may purchase some just to see what it looks like on some of the kits I have in stock. I tend to think LightSheet is going to be the way to go on the new E-A (IMO).
Jack :wave:
I've used Mike's lightsheet on a few applications. It's fun to work with, and you're right: it's pretty simple.
Read the instructions though. The voltage off the inverter is about 80V, enough to be a hazard if you shock yourself.
grantf said:
never had a jolt off of 220 but 110 on more than one day durring work, that numbing fffffffffvvvvvvvvsssssssss sensation is not so pleasent.
how many amps dose the light sheet draw?
The amps are quite low, but it WILL wake you up in a hurry! Use the same precautions you'd use in any high-voltage application.
1 - 17 of 17 Posts
