This is trax70....... www.trax70.comjason crist said:jamie you r awesome..........
what is a trax 70 ?
Jamie ORL 06/10 at Trax 70-they were running 5.9-6.0's on Sun with 4300's.They will only get faster as the temps get warmer.Are you going to make it?I believe they are running on 06/03 and 06/08(Fri night race)if you want a little practice time.Jamie Hanson said:Caps are AWESOME>......... I am dying to get to TRAX70 and run on caps again.
jason crist said:Pat
no caps for me
man haven't you beat me enough this year .....now you want more ?.......lol
jason crist said:yokman you r so right....
i have atleast 3 wins over ya in oval and 1 in off road....
Davz: I lost your e-mail, think you could kick that tri-clone outdoor set-up sheet my way, actually I think I’m on to something with my set-up, so I was looking for just these things to go off ofdavz said:I have a very good setup for 4300 for the lightning. Gimme your email and I will try and scan the sheet and email it to you.
The car ran 5.8 sec laps for about 2 minutes and ran 50 laps.
Thanks 4 posten your set up U used at SCHJamie Hanson said:A few people have asked about my setup from the Steel City Hobbies National race a month back (4300 setup). Sorry it has taken so long but here it is.
Lightning chassis with the old style rear top and bottom plates.
--RF: Red progressive spring/ 4 degrees castor / -1 degree camber / G6 tire
--LF: Red Std spring / 2 degrees castor / +1 camber / white tire
--LR: Silver spring / 50 weight / white tire
--RR silver spring / 50 weight / Gray tire
Other notes: I ran the Windtunnel front end springs in this car. Center shock was an HPI with a #2 piston and 70 weight oil. I always run the ORC Super Soft T-bar. The car had stock front castor blocks. Just enough preload in the front so there is just a touch of sag in the left. The car ran a centered t-bar with the pod offset to the felt. Left rear wheel in as far as I could get it and the wide right side hub with no axle spacing.
I ran the T-HD body.
This is the setup I run everywhere for a starting point minus the tire combo. I ran this SAME setup and Seaford, DE except for a tire change.
