The center mount changes where the shock puts the load on the car. If you move the mount forward, the preasure point is closer to the front, in turn causing more steering.
The effect your feeling Scott is weight transfer from the rear of the car to the front of the car. Basic rule..... the more weight that is in the back to begin with, the more that gets shifted forward when letting off the gas. Since moving the batteries on the lightning is a jump, one thing to do is lower the shock angle in the center. If you draw an imaginary line to mimic the center shock, picture where in out in front of the car it would hit the carpet. The further out it is, the more steering there will be. That point is where the weight is shifted to when letting off the gas. Lower the shock angle and it brings that point back a little closer to the rear of a car which will give you less steering when getting off power.
