All:
I have a neighbor who shorted the positive terminal on his White LT 1650 lawn tractor. He cooked a couple of wires and the main fuse and I got it running without much trouble but the charging light on the instrument panel is illuminated and it is not charging.
There is a very small (1" square X 3/8" thick) two bayonet connector device in line to the engine (red wire) that my neighbor believes contains a diode. This device has Buss 253 marked on it but I have not been able to determine what the device is. If it does contain a diode, I am pretty confident my neighbor's short would have cooked it, as he almost certainly exceeded the peak inverse voltage for it. I don't have much for tech data on this machine but I found what appears to be a pretty good wiring diagram on Partstree. That diagram and parts listing does not contain any diodes but since the device in question is in the wiring to the engine, it may be part of the Tecumseh V-twin powerplant.
Any thoughts on this or anything else that may have been spiked and could cause the charging system to fail would be appreciated. I am trying to help out my neighbor with minimum cash outlay.
Thanks,
Jetmech
Thanks,
Jetmech
