1 - 2 of 2 Posts
im taking my 12 yr old daughter racing with me saturday. i race a pro 3 in spec truck and it is very competitive. she will be racing an l4. need to know a basic setup for a snowbirds size flat carpet track.
thanks
john mc
Front end: Left middle outer hole, spacer 1 in front, 1 rear on left side both in front on right. Standard front end spacers in same manner, but with Wolfe kingpin both on top on left, one on bottom, 1 on top on right. Springs are Wolfe standard Green springs Left and Right. Tires are Jaco Blacks 1/4 left front covered 1/4 to 1/2 of right application of compound (Paragon). 2 degrees positive camber left, 2 to 2.5 negative on right.
Rear: White Jaco full surface of compound
Side Shocks a Silva 30wt oil, left blue , right gold
Center shock 40 wt (threaded Team shock) #1 piston, silver spring
Tweaked Right front, Left rear
Body Proform MC 2002 lw, spoiler only.
plate, front end moved to short wheel base.
Use a 6cell tray will battery placed in the middle all the way out.
1 - 2 of 2 Posts
