kohler command 12.5 hp pro series the problem im having is with the carb you can start it and it runs great for 20-35 sec then shuts off and if you look were the air filter bolts to the carb the whole carb is full of gas like almost over flowing. any help would be great.
I would suggest doing a carb cleaning. Needle and seat seem to be the problem. Looks like it has a plastic float so that should not be an issue. Brass one can develop a pin hole in them and fill with fuel, causing it not to function properly.
I have a friend who has a Kohler flooding issue also, says it puffs black smoke, and now it barely runs, and crankcase is full of gas. I'm going to check the needle to see if its either stuck or maybe not seating correctly..:)
