I found some great Kingpin lube. It is very thick. It comes in the HPI micro fornt end tuning kit, I found it in my box, and it seems it is going to work well. What does everybody else use?
I would say that's it's imperative that you use some form of lube on the front king pins it makes the front end work so much smoother and keeps it from binding up,get some of john's goop and you will know what I mean immediately.Ballblazer said:I must say I have never used any type of front kingpin lube/dampening fluid. I would think that it would mostly attract dirt. So what are the benifits to using the lube/dampening fluid on the front end?
