Hi,
I have a mower that ran perfect a month ago, but now when blades are engaged it runs erractically. The mower surges idleing or at full throttle. When the air cleaner if off, it slightly backfires (out the air cleaner opening). I cleaned the bowl of the carb, but it did not help. It is 14 Degrees out today would that effect the engine? Even after the engine was warmed up I still have the same problem. I'm thinking I need to clean the entire carb rather than just the bowl. Thanks for any help.
Update: I cleaned the carb completely (was not dirty at all), I changed the spark plug, (the old one had cracked porcelin) I set the gap to 30, but then read in the manual it should be 24-28. So, tomorrow I will change the gap. I noticed that if I hold the throttle (to stop it from surging the engine runs fine) There is one adjustment screw on the back of the carb, I have it turned out about 1.5 turns from the closed position. Anyone know where that should be set. Please help... Geo -- 30yr. Thanks
