Here's a Conny going for a dip.
I had this old 18inch AMT 1701 - and based on a dream I once had about a conny crashing in the sea, I came up with this diorama.
Its the first time I've tried modeling waves and rough seas - I've done a ton of flat calm seas - its not perfect and not quite what I had in mind!
I figured, that after a fall through the atmosphere, the saucer would snap off due to air and water resistance pulling away at the primary and secondary hulls in opposite directions.
It may not be exactly what you had in mind......But I'd say they came out pretty darn good.
Realistic oceans and waves have been a bit of a passion and a quest of mine and I'd say at least photographicly they look great.
Please share the 'how'd ya do that'.
Whoa! That's gonna leave a mark! :eek:
Great job, so far. Is there going to be any sort of explosion along the "neck" area?
Just a thought..I bet everyone on board went the other direction, like on the show, when she hit. Of course only red shirts will be hurt or even kill'd.
I think they'd be res splats after that!
Thanks for the compliments guys, I did model in a ripped neck section rather than explosion but I pulled it off when I re-positioned the saucer and couldn't be bothered to glue it all back on - this was just for really and I didn't want to commit too much time to it.
The sea was simply made from plastic sheet, sticky tape and woodland scenic water effects.
i wanted a slight transparencey and depth, so I glued 2 bottle lids to the base, then roughly layed strips of plastic sheet over them - glueing them in place. I then got some clear sticky tape and bunched it back on itself to make sticky balls/bunches and stuck them to the plastic sheet wherever I wanted waves. Then I took strips of sticky tape and stuck it down in strips over the mounds - perhaps pinching the top of the mound to make a crest of a wave. I then plastered on the water effects stuff to add to wave crests and to give it surface detail. Foam was made with PU glue - it foams up as it dries.
I've had some good results with that method - I'll do it step by step with pictures if anyones interested?
Mike
Starship Class
That one model kit has probably suffered more abuse, intentional and unintentional, than any other kit ever manufactured!
:jest:
Seriously, cool dio! Can't wait to see it painted up and decaled. :thumbsup:
So you have never seen the original version of The Doomsday Machine? :jest:
The episode is still my favorite one of all time! :)
