SHAMELESS SELF PROMOTION ALERT:
The armature of the ParaGrafix
Hero Landing Gear is made of brass, which conducts electricity quite nicely. Two of the legs could be used for a single power circuit, or all three could be used with one being a common ground for two circuits.
Over on the lighting forum Teslabe has a great solution for the "I picked up the model and now the lights went out" problem this could cause:
http://www.hobbytalk.com/bbs1/showthread.php?t=252929&highlight=capacitor .
As I've done with all my builds, they are self contained and powered by ether
"Super Caps" or rechargable batteries and are never hardwired to anything.
I too like to pick up my builds and have them still powered up. The kit drives
both the type of contact I use and the type of power needed to supply the kit when off it's charger base. For simple lighting, 5 leds or less, I will use Super Caps and can get about 10-20mins per charge. For more power hungry
builds, I use rechargable batteries like Lithium Polymer (LiPo). For all my J2 builds, from LM, PL and now my Moebius, I always used the landing gears to get power up to the ship and a matching base to set the ship on for it's power. The legs had very small wires running down the stair case back and covered with a thin sheet of plastic to hide it, then under the pivot joint at the base of the leg into the pad.Then on the bottom of the pad I used Copper
tape and soldered the wires to that. The base had small contacts that lined up with correct pad for the +/- circuit.
Using Paul's landing gears would have made it easier, so you may want to think hard about using them.....:thumbsup: Here are some reposts of my MIM
Seaview, it has super caps and some reposts of my PL J2. I will post pictures of my Moebius as soon as I get all the electronic in for it and can start the build.
P.S. I no longer have the base for my PL J2 or my LM J2, the last time I saw them was as the box that had them flew off the back of a pickup truck when I was moving......:drunk:
