1 - 20 of 52 Posts
nice work, for me i would be scared to death my exacto would slip while scribing the hatch to open it up. SLICE !!!!
You are one sick puppy, Duct! I mean that in a good way :)
Those are looking super - and I thought your previous work looked amazing. This is going to be one fantastic model!
Great work.:thumbsup: I had a feeling you were gonna put the NGS scanner up there.:D Your really tricking the ship out. Love it. Did a great job of creating the radar. I dont believe we saw that in the show, correct?
Is the base of the radar made out of the top of a small spray can??
i think the radar was visible in the episode "visit to a hostile plant" season three
I do rememeber the scanner but not the radar. The scanner was the piece of hardware John worked on I think the first season.Correct??(just above the hatch.) Duct has also build the radar in the back of the ship where the larger access hole is. I dont remember it in the third season. Was someone working on it in an ep, was it viewed from a longshot of the ship in space?
Don't take this the rong wae....but....Unless your pod Doors open, why add a frame that didn't exist?
Your crash doors and main door sliding are prolly above my experience level BTW.
Your EVA cable connects by the door push buttons is a superb touch too. I can't WAIT to see your landing gear treatment.
www.tsdsinc.com
I do rememeber the scanner but not the radar. The scanner was the piece of hardware John worked on I think the first season.Correct??(just above the hatch.) Duct has also build the radar in the back of the ship where the larger access hole is. I dont remember it in the third season. Was someone working on it?
John Robinson went up on the roof to fix the scanner in the 2nd episode. The other piece was seen on the full-scale mockup in Hostile Planet. That much I remember!
--Henry
--Henry
I will have to look at the episode.Dang surprised i missed it. I have seen Hostile planet several times.
Thanks Henery. I cant believe I missed that. The radar is huge in comparison to the badly scaled full scale mockup.:lol:
Discussion Starter #20 (Edited)
Okay, guys it took me the better part of this afternoon to make the list, but here it is :
the final complete list of mods.
Ductapeforever’s
Jupiter 2 Series Spacecraft Modifications
Astrogator
1. Cut wedge from Astrogator body and base.
2. Cut fingerholes in Astrogator body
3. Scratchbuilt stool for Astrogator (using wedge cut from base)
4. Added trim strips to the upper Astrogator surface
5. Added ‘General Electric’ logo decal to Astrogator Ring surface
6. Added spiral decal to gyro top in Astrogator
Station One (Communications Station and Airlock)
7. Cut door from interior airlock bulkhead
8. Rebuilt Airlock doorframe
9. Added strips of Evergreen to door to replace material lost when
door was cut from bulkhead.
10. Added missing bulkhead to complete full airlock
11. Added tracks made from Evergreen ‘c’ channel for doorslides
12. Scratchbuilt airlock inner controls panel
13. Duplicated decal for airlock controls, Cut out viewscreen
above Communications Station.
14. Scratchbuilt valve and pipe assembly inside airlock
15. Cut Airlock door from Outer Hull and replaced material lost
with Evergreen strip
16. Opened window in Airlock door, Printed graphics for
Communications Viewscreen on clear acetate, added light to
viewscreen
17. Rebuilt tether attachments and airlock controls on outer hull
18. Added new Fire extinguisher to inside of airlock
19. Added tracks to inside of outer hull for sliding main airlock
door, discarded decals for side of Communications Station
drilled out these details in side console.
Station Two (Electronics Bay)
20. Added pull handles to equipment panels above electronics bay
21. Added pull handles to equipment panel above Vector recorder
22. Added swivel mount to navigational gyro assembly to allow
free movement
23. Added clear acetate between bulkhead and tape recorder insert
24. Added microphone and cord to Vector recorder
Station Three (Utility Room Bulkhead)
25. Rebuilt Cabin Pressure control panel
26. Scratchbuilt wall mounts for Emergency Oxygen Bottles
27. Cut door from bulkhead
28. Replaced material lost when cutting door
29. Scratchbuilt lower Ladderwell and fifth step
30. Added ‘c’ channel tracks for sliding door
31. Added bulkheads for utility room interior
32. Added bulletin board and star chart print
33. Added Fire Extinguisher
Station Four (Elevator )
34. Drilled out ends of tubes in cage frame
35. Hollowed out Elevator control upright and scratchbuilt slide
lever
36. Added control lights to upright
37. Added ‘L’ brackets to enhance elevator track
38. Cut door from bulkhead
39. Replaced material lost when cutting door
40. Added ‘c’ channel tracks vertically for slideing door (Door on
series opened two ways, in season 1-2 it opened inward hinged
on the right, in season 3 it slid upward )
41. Scratchbuilt airlock interior
42. Scratchbuilt angled extensions for rear of Spacepod
43. Scratchbuilt Spacepod door
44. Added black bumpers to bulkhead walls
45. Scratchbuilt airlock controls
46. Added Fire Extinguisher
Stations Five, Six, and Seven (Stasis Tubes)
47. Drilled stasis regulators for added wireing
48. Added Vinyl panels to rear lower one third of stasis tubes using
silver Monocoat aircraft trim
49. Painted rear of clear Magna Panels Model Master
Turquoise # 2965
Station Eight (Flight Deck)
50. Scratchbuilt new Tripod control
51. Added Microphone and cord
Outer Hull
52. Added frames to all hull openings
53. Drilled out and enhanced thrusters
54. Fabricated working Collision Shields for main viewport
55. Added tracks for Collision Shields
56. Added EVA equipment locker to right gearwell bulkhead
starboard central gear strut
57. Scratchbuilt NGS Scanner antenna
58. Scratchbuilt Main Surface Radar antenna
59. Added olio sleeves to gear struts
Note: Kit Fire extinguishers were not used in favor of larger
bottles purchased separately
...unless something extraordinary happens, this is all the mods I intend to do to the ship itself. I will make a whole bunch of assesories.
1 - 20 of 52 Posts
