Is there a metal gear servo for a Mini T. I have seen the HS-55 but it is plastic. Is there a metal gear servo in this size. I am using a spy and XXL. Thanks for the time.
Hillbilly,hilbilly said:Dustin Losi frk - I hope that my post helped you out - all you really needed is to look at the chassis mod cause the HS-81mg will plug right in to your current setup. I posted the rest to try to help others that might want to make the jump or are having problems with their stock setup. (Also you might want at some date in the future to put the "stock" electrics back in and use the SPY and XXL for a M-18!)
