I'm not having much luck using tthis set up station on my carpet oval 1/10 pan car. I dont think it is the right one for my car. The toe rule deal is to long or to short and I need some help. Does any one use this type of set up? Can you help me thanks
Most set up stations won't allow you to measure the toe on both wheels at the same time. Since track widths can vary from car to car and are adjustable, they make the toe scale so you can slide it from one side to the other. If you measure the right front first (i typically set mine to 0) you can slide the gauge over and check how far out from 0 the left front is in relation to the right front.
If you can find it you want the hudy pan car station. Bring your cars over next time at the track and ill get you started.
I second the Hudy pan car system. I have had it for about a month and it works great. You can set Toe, Caster and Camber all right there. It takes longer to get it out of the box and put it together than it does to use it.
Discussion Starter · #9 ·
Yep I should be there at 9:00am. I will have to leave at 1:pm I will be back by 2:15 ish. I need to go and pick up my boys. I am doing track maint. I am building a hobby shop inside for new/used parts.
