general rule with EXCEPTIONS
Front of car is entry to middle
rear of car is middle to exit
right front,left rear- entry steering,exit bite
left front,right rear -exit steering,entry bite
right side is for generally getting in
left side is for generally getting out
if your loose going in,you'll just going to get looser coming out
if your tight going in you're going to be tight going out,but you can over get up on the wheel too much and unload left rear and get looser
try and always add bite to which ever end is loose,try and never take bite away,bite is your friend,but stuck isn't.unless your running 2 cellopen modified.
Free is fast, loose is slow.
Once you get general setup close for track,camber is a really good tuning aid,big gains on left front
more than 30% dual rate ,you're just scrubbing fronts
