The car clearly represents a 69 model, is a functional pull back wind up and has the rubber sleeves on the tires intact.
The body and base are plastic and does not exactly resemble another casting from any other maker that I know of.
Scale comparison with a Hot Wheels 69 Charger.
Removed the screw from the base for a closer look inside.
I have seen pictures of two other examples so they are out there,
the thing is that so far nobody can identify the maker.
Thanks for any insight
Cheers
Eric
Thanks for the reply. Interestingly enough, the example on your site is one of the two others that I seen.
Wow some nice 69 Chargers there my search goes on!
Mego / Speed Burners thats a great lead Thanks again!
Eric
No updates. So far only the 3 examples that have been produced, none of which are packaged for confirmation.
Eric
Administrator
The mirror finish should also help narrow it down some as well. I can only recall seeing that finish noted as used by 2 or 3 companies so far that I can remember. Pull backs are everywhere though! One that keeps tugging at my memory was a trackset offering that had pull back racers in them. When I run across it again I will try to remember to reference it here. :cheers2:
