1 - 3 of 3 Posts
Here's my next two projects. 1/43rd scale
I bought a metalic blue Duplicolor for the GT40. That's what I was asking about Krylon primer and Duplicolor primer. The guy at NAPA said it would be no problem. I guess I'll test first. I find the paint sticks better if primed.
Mike if those are my resin bodies Duplicolor will work fine right over the resin no primer needed. Just make sure the body is good a clean no finger oils. Also I do two light coats then a heavy coat. If you missed any oil on your body you will see the fish eyeand you can vclean and lightly sand to correct the problem. Taymia makes a great white primer for those times you need one.
Roger Corrie
1 - 3 of 3 Posts
