Status
Not open for further replies.
I have a Husqvarna model 141.The problem is the switch won't shut the saw off. I tried two other switches from other Husqvarna saws and they don't work either.I cleaned all connections from coil.Don't know what to try next. I don't like choking it to get it to stop. Thanks
sounds like it may be the wire going to the stop switch may be cut in too in the inside of the wire the plastic coating may be ok but inside it may be torn in two
the best way to tell is do a continuty test on the wire see if you can get current from one end to the other if no current its time to consider a new wire
hope this helps
calvin
Status
