1 - 1 of 1 Posts
Hudy have released the Star-Box, a unique starter box designed for 1/10 & 1/8 nitro on-road cars. Claiming to be the world’s lowest, this ultra-compact starter box design is very lightweight, only 575g / 1.27lb (w/o batteries). A uniquely designed support bracket recesses into the starter box to allow the starting wheel to be fully engaged, while adjustable backstops allow you to fit 1/10 and 1/8 on-road cars.*The Star-Box has an ultra-cool stylish design and comes fully assembled, ready to use. The long-life drive belt system runs off a powerful 775-type motor (with fan) which is powered by two standard-size 7.2V battery stick packs (not included). The CNC-machined aluminum housing has a high-quality black-coating for extra durability and countersunk housing screws are recessed into the surface to eliminate unwanted protrusions. An integrated switch for comfortable on/off switching is attached to the wiring harness with extra-thick cables and quick-change fast-on connectors meaning no soldering is required. The quick-change starter wheel system was designed to allow for fast & simple replacement of the starter wheel using only 3 screws and finally an integrated composite handle with ergonomic back cover allows for comfortable carrying.
- Unique starter box for 1/10 & 1/8 nitro on-road cars
- The ultimate star among all starter boxes on the market
- World’s lowest, ultra-compact starter box design
- Very light weight, only 575g / 1.27lb (w/o batteries)
- Powered by extremely powerful 775 type motor with fan
- Uniquely designed support bracket recesses into the starter box to allow the starting wheel to be fully engaged
- Maximum efficiency due to maximum engagement with the starter wheel
- 3-axis adjustable chassis brackets for precision fit of any 1/8 or 1/10 on-road car
- Fully assembled, ready to use
- Powered by two standard-size 7.2V battery stick packs (not included)
- Premium quality, long-life drive belt system
- CNC-machined, black-coated aluminum 1-pc housing for extra durability
- Countersunk screws recessed with surface; no protrusions
- Integrated on/off switch for safety and comfortable use
- Extra heavy-duty wiring with quick-change connectors; no soldering required
- Super-easy starter wheel changing by loosening just 3 screws
- Integrated composite handle with ergonomic back cover for comfortable carrying
- Ultra cool and stylish exterior design
Source: Hudy [hudy.net]
</img>
</img>
More...
1 - 1 of 1 Posts
