1 - 3 of 3 Posts
I am trying to find some info on the HPI white spring i see alot of people using lately.. What is the pound rating on it?? All i can find is the # 6833 white prog spring.. It is listed as 16.7lbs.. Is this the spring?? I have only seen people in the past using 10lb or less center springs, unless on a banked track.. anyhoo thanks in advance..
yes Burbs that is the correct one i have ben running that spring with good success on flat carpet thanks to Frank Ulbrick!!
Averaged out on a spring gauge with the soft begining and hard end it averages out to be more like a 10-11 lb spring depending on how much travel you take into consideration.
1 - 3 of 3 Posts
