1 - 1 of 1 Posts
Original parts for the HPI Formula Ten chassis has arrived rcMart. Please find the product detail from the following list and don't miss the chance to order the best HPI parts for your hottest machine now.
Where to buy:
http://www.rcmart.com/catalog/for-hpi-hpi-formula-10-c-595_737_1415.html
102814 HPI (#102814) F10 Main Chassis 102815 HPI (#102815) F10 Front Chassis / High Nose 102816 HPI (#102816) F10 Front Upper Arm 102817 HPI (#102817) F10 Battery Holder Set 102818 HPI (#102818) F10 Motor Mount Set 102819 HPI (#102819) F10 Servo Saver / Friction Plat 102821 HPI (#102821) F10 Steering Knuckle Set 102823 HPI (#102823) F10 Plastic Bushing 102826 HPI (#102826) F10 Rear Wing / Type A 102827 HPI (#102827) F10 Barge Board / Type A 102828 HPI (#102828) F10 Gear Diff. Hub (OR) 102829 HPI (#102829) F10 Wheel Hub Right (OR) 102831 HPI (#102831) F10 Rear Axle Shaft 102832 HPI (#102832) F10 Helmet Parts Set 102833 HPI (#102833) F10 Front Axle Shaft 102834 HPI (#102834) F10 King Pin 102835 HPI (#102835) F10 T-Bar (1.5mm) 102837 HPI (#102837) F10 Slick Tire Rear D-Compound 102838 HPI (#102838) F10 Top Deck 102878 HPI (#102878) F10 Ball Diff. Set (64P-95T) 102879 HPI (#102879) F10 Threaded Alum. Shock set 102906 HPI (#102906) F10 Bridgestone Front Tire (S) 102907 HPI (#102907) F10 Bridgestone Rear Tire (S) 103016 HPI (#103016) F10 Bridgestone Front Tire (M) 103017 HPI (#103017) F10 Bridgestone Rear Tire (M) Where to buy:
1 - 1 of 1 Posts
