Put 'em in hot water 'till they become somewhat pliable. Then, carefully bend/flex them back into the correct shape. If they need to be flat, take them out of the water and place them on a flat surface, then put something flat and heavy, like a book, on them.
Some people have recommended to me to use "almost boiling water". But not boiling water - it will melt the resin!
Don't let the resin part touch the sides of the hot water container - again, it may cause the part to slag or melt where it contacts the water container.
Remember that the thinner the part, the faster it will soften. If your part has thin and thick sections, the thin ones will soften first.
If you want to correct a warped part, you may have to bend it a little past the correct shape to account for the part tending to spring back to its old warped shape.
Dip the part in cool (not cold) water once you are done.
You can repeat this process until you get the desired results.
Huzz
