I haven't had time to keep up with this blazing hot thread in recent days, so here's a mega post to bring me up to date.
Chuck PR asked my opinion of the Casmiro First Pilot plans:
I do not have time at present to do a detailed comparison of these with my own research, but I did once do that with his production version. Unless these are substantially different my opinion of them would be the same. To wit, Casmiro's plans are the most beautiful artistically of any of the plans I've seen. The way he calls out various details is truly top notch and the overall plans are a work of art. They are really quite good and would rate a B+ grade from me on accuracy. Given how long ago he made them and the references that were available then, I'd say they are remarkably good. I still think the Sinclair plans get higher marks for accuracy overall. I'd give Sinclair an A-. The best plans (and I know they are small and have a few minor inaccuracies in them) are the Polar Lights decal placement guides from the PL instruction sheet. For overall proportion, shape and placement of the major components they are the best publicly available. My only major quibble with them is the spherical bridge shape.
Griff:
I'm sorry to see you've banned any discussion of bridge issues from the thread -- but you're the boss. As the originator of the thread I'd like to say that bridge size and orientation are at least tangentially related to the issue at hand. And what's more, I was
just about to post some new data about the pilot dome. Do I need to start a new thread for it? If so, I'll post a pointer here at least to let folks know about it.
4MM:
Thanks for door animation! That is too cool. My original idea was that under the overhanging doo-hicky (I won't call it a control room, it's too small and inaccessible) was an unseen solid part where the doors attache in separate tracks. This is much like the lower, visible one on X15-1A's renderings. Since the door curves are still at an oblique angle there, I figured that the doors could slide past each other without having to move down or back, as long as the edges that mate up are beveled in the proper (and variable) angle. Your solution works too, and still shows the increasing space between the segments as they come to rest. Thanks!
To all:
I use "MGagen" and don't use my first name at all for a good reason. Some of us do not want our first and last names to occur together in an easily Google-able way for professional reasons. Not everyone wants hundreds of "fanboy" posts to come up in a search engine when prospective clients are Googling our names. In future, could everyone please refer to me simply as MGagen or just as M for short. Thanks!
X15-1A:
I think it is interesting to note that Jefferies calls out the deck level of Engineering as 2 feet below the Hangar Deck level on his Phase II cross section. Also, there is a way to have your cake and eat it too. Here's a graphic I did many moons ago to show how the conduits seen in Engineering could be made to attach to the nacelles. It takes the Jefferies specified "2 foot below centerline" deck level into account.
How Engineering might be oriented.
In my example, I've rendered the connection points as right angles which causes the conduits to have a wider configuration than on the show, but the same would work if you stuck with the visible angles. I also like the way it means you could walk up to the mesh and look down into the rest of the structure. It could also mean that an under floor conduit might stretch forward to link up under that dilithium crystal McGuffin in the middle of the deck. Food for thought.
M.
