MGagen said:
The "squashed soccer ball" shape actually can work and has an interesting feature: Because each section revolves around the central axis, the door sections separate as the doors open, giving room for the sections to slide past each other. Also, they could come together to present a nearly seamless outer surface, rather than the stair stepped one necessary with a spherical door. Here's a study drawing I made back in early '04 to illustrate the point:
That is cool!
However, making it work it still doesn't reconcile the quarter sphere hangar bay doors that MJ shows in his cross sections with what appears on the back of the miniature.
And on the hangar bay miniature, the doors appear very much to be spherical as they open. Tho from the pov the perspective can be misleading.
But at least after this I know that MJs bridge fits exactly as he shows it. And correcting a couple scale mistakes I made in photoshop, I know that his hangar bay fits to scale as he designed it. So I'm now thinking that he really did design this thing w/o Irwin Allen contradictions.
[Edit] And now I'm backtracking on the whole elliptical shape. Was it in fact real? As I go back over pictures of the 12' miniature's hangar bay doors, I see no evidence that they were elliptical at all. If that control room or whatever it is isn't centered on the axis of the door, then the miniature's could be spherical, which would make sense from a modeler's (Datin's) pov, as it would have been easier to make. MJs ext ship drawings do show an ellipse, but the drawings are very sketchy as to the interface between ext and int. His drawings (the ones I have anyway) of the int of the shuttle bay are either distorted or (I don't believe) not accurate, none of the lines are parallel. It's sort of a side view of forced perspective., everything narrowing as you get closer to the doors. It's possible that on the fairly crudely reproduced ext views (Making of ST book) that there was some sloppiness in the drawing or distortion in the repro, I suppose.
Way OT for this thread: What shape do you think those doors really were?
