1 - 3 of 3 Posts
does anyone know if theres an common problem with honda small engine? its a 9hp pull start. it gets spark 1 time then none the next.maybe someone else might of had a issue similiar. thanks for any help. :thumbsup:
Have you tried a new spark plug? Honda's are pretty fussy about having a good plug.Does your engine have a low oil cut off sensor? Try disconnecting the wire to it and see what happens.
i did unplug oil presure switch, i have tester on spark plug wire. when it don't get spark theres none even getting to spark plug .
1 - 3 of 3 Posts
