I had a similar question 10 years ago here, but this is a different GX31 engine, this one on a Honda "stick edger." Late last season, I could only run the edger maybe two or three minutes before it would start to stumble at throttle, and then die out. It would often restart immediately, then die out again. This season, it can only run about 30 seconds and it dies out.
I've also noticed it leaks oil from the end of the cylinder head. I don't know if it's from the plastic cover on it, or if I may have a bad cylinder head gasket, which could also explain the dying out when the engine starts to warm up.
From my "fiasco" 10 years ago (which I never fixed--I found a slightly used engine instead), I have an engine with low hours and a few parts I can scavenge. When I took the engine off of the stick edger, I noticed the fins on the cylinder block were dirty from oil. The coil also had some oil on it, and I know from past experience that engine oil on electrical components is not a good thing.
So I can swap over the coil, and, might as well do the spark plug.
I also wonder if the fuel filter is plugged. But, I don't know how to get at the filter--can I fish it out through the fuel filler, or does the rubber plug on top of the gas tank just pop out so I can access the hoses and filter that way?
All the fuel lines look good so far--it appears the black lines are the fuel lines, and the reddish-clear line seems to be a return to the carburetor from the tank.
Other than the stalling, the engine runs OK. There is no tapping or knocking from inside, unlike my other GX31 which had a tapping in the motor once it warmed up (as it was overheated from clogged fins on the cylinder).
Is there any reason to be concerned over the cylinder head gasket? I've never done one on a tiny Honda engine before, but I imagine it's not too difficult. And that plastic cover (cylinder head cover?) always seemed to leak slightly on all of my GX31 engines.
Final question--how do I get the clutch shoes off? Very thin 17mm hex bolts hold these on, apparently. I saw a trick using a small oil filter wrench to hold the clutch while turning the bolt. Or can I try an impact on it? I don't want to jam anything in the flywheel and risk breaking the fins. I also don't see any locating holes in the flywheel and engine where a dowel could be inserted to hold it tight.
Thanks!
Thanks!
