there should be a single wire that runs over the air box from a kill switch to the coil, you may need to removed the top cover to the engine and unplug the wire from the coil , after you disconnect it you can now pull the recoil again and test spark,still no spark make sure your magnets are good on the fly wheel and if so you have a bad coil.
Discussion Starter #6
Thanks.
