Got engine running well following a rebuild...carb problems now...Took carb off to clean out and all the gaskets fell off the two retaining bolts...is there anyone out there who might have a drawing of which gaskets go on either side of the carb and the air cleaner....looks like I have a slight air leak which is making the engine run too lean. Mixture of metal gaskets, fibre and a black plastic distance piece which goes between the carb and the inlet side of the head..tried various combination of gaskets and can't quite remember the sequence. :dude:
Here is a diagram of the gasket installation.Make sure you align all the pulse holes in the gaskets and insulator "behind" the carb to the right of the large intake hole.The small hole in the gasket in front of the carb is on the left side of the large hole.Hope this helps.
